[gdal-dev] OGR OVF has no identified FID column
Brent Fraser
bfraser at geoanalytic.com
Fri Aug 20 10:16:27 EDT 2010
David,
GDAL: POINT (0.0 2.000000000021871)
SQL Server: POINT (150 150)
That IS strange! There could be a problem with GDAL's or SQL Server's
encoding/decoding of WKB, or it could be related to data type (geometry?
geography?) or the lack of a Spatial Reference System?
Best Regards,
Brent Fraser
David Lowther wrote:
> D:\Utility\ms4w\tools\gdal-ogr>ogrinfo test.ovf PointData --debug on
> ERROR 4: Update access not supported for VRT datasources.
> OGR_ODBC: EstablishSession(DSN:"CLO", userid:"un", password:"pw")
> ODBC: SQLConnect(CLO)
> OGR_ODBC: Table PointData has no identified FID column.
> OGR: OGROpen(ODBC:un/pw at CLO,PointData/00FB9BB0) succeeded as ODBC.
> OGR: OGROpen(test.ovf/010870B8) succeeded as VRT.
> Had to open data source read-only.
> INFO: Open of `test.ovf'
> using driver `VRT' successful.
> OGR: GetLayerCount() = 1
> Layer name: PointData
> Geometry: Unknown (any)
> OGR_ODBC: ExecuteSQL(SELECT * FROM PointData)
> Feature Count: 1
> Extent: (0.000000, 2.000000) - (0.000000, 2.000000)
> Layer SRS WKT:
> (unknown)
> PKey: Integer (10.0)
> Feature: Binary (0.0)
> OGRFeature(PointData):1
> PKey (Integer) = 1
> Feature (Binary) = 00000000010C0000000000C062400000000000C06240
> VRT: 2 features read on layer 'PointData'.
> OGR_ODBC: 3 features read on layer 'PointData'.
> ODBC: SQLDisconnect()
> And, why do you think it is saying 0.0 2.000000... for the point when the
> SQL query says?
> 1 0x00000000010C0000000000C062400000000000C06240 POINT (150 150)
> David Lowther
> Coordinate Solutions, Inc.
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, August 19, 2010 5:21 PM
> To: David Lowther
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] OGR OVF has no identified FID column
> I think it's faster since it doesn't have to enumerate all the tables,views,
> etc.
> so how do you get for attributes names when you do a
> Brent
>> Still doesn't see the FID but is way faster!
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="PointData">
>> <SrcDataSource>ODBC:un/pw at CLO,PointData</SrcDataSource>
>> <GeometryField encoding="WKB" field="Feature"/>
>> <FID>PKey</FID>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> ogrinfo test.ovf --debug on
>> OGR: OGROpen(ODBC:un/pw at CLO,PointData/02799B88) succeeded as ODBC.
>> OGR: OGROpen(test.ovf/010270B8) succeeded as VRT.
>> 1: PointData
>> Does the datatype of the FID column matter? I have it as an int, does it
>> need to be guid?
>> David Lowther
>> Sent: Thursday, August 19, 2010 3:49 PM
>> To: David Lowther
>> Yeah I saw that after I sent the message. Take out the <SrcSQL>, it's
>> really
>> only useful if want to do "special" things, and it can kill spatial
> indexing
>> on
>> ODBC datasources. Does this work any better:
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="UserPoint">
>> <FID>PKey</FID>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> Brent
>>> Brent,
>>> Thanks for the reply. On initial read I thought you had found my issue -
>>> that I was trying so many things I finally messed it all up. But on
> closer
>>> inspection I am aliasing the PKey column to FID in the SrcSQL (select
> PKey
>>> as FID, Feature from PointData).
>>> When <FID>FID</FID> ogrinfo returns:
>>> ODBC: ExecuteSQL(select PKey as FID, Feature from PointData) called.
>>> OGR_ODBC: Table SELECT has no identified FID column.
>>> OGR: OGROpen(test.ovf/00ED7090) succeeded as VRT.
>>> 1: UserPoint
>>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02719D10) dereferenced and now
>>> destroying.
>>> When <FID>PKEY</FID> ogrinfo returns:
>>> ERROR 1: Unable to identify FID field 'PKey'.
>>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02C39D18) dereferenced and now
>>> destroying.
>>> FAILURE:
>>> Unable to open datasource `test.ovf' with the following drivers.
>>> -> ESRI Shapefile
>>> David Lowther
>>> Sent: Thursday, August 19, 2010 3:15 PM
>>> To: David Lowther
>>> How about using:
>>> <FID>PKey</FID>
>>> but that doesn't explain why it takes a long time...
>>> Best Regards,
>>> Brent Fraser
>>>> List,
>>>> I have an OVF layer defined as follows:
>>>> <OGRVRTDataSource>
>>>> <SrcDataSource>ODBC:un/pw at CLO</SrcDataSource>
>>>> <SrcSQL>select PKey as FID, Feature from PointData</SrcSQL>
>>>> <FID>FID</FID>
>>>> </OGRVRTLayer>
>>>> </OGRVRTDataSource>
>>>> The ODBC connection is to a SQL Express 2008 database. The PointData
>> table
>>>> is defined as follows:
>>>> CREATE TABLE [dbo].[PointData](
>>>> [PKey] [int] IDENTITY(1,1) NOT NULL,
>>>> [Feature] [geometry] NULL,
>>>> CONSTRAINT [PK_PointData] PRIMARY KEY CLUSTERED
>>>> [PKey] ASC
>>>> )WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY =
>>>> OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
>>>> ) ON [PRIMARY]
>>>> This query
>>>> select *, Feature.STAsText() from pointdata
>>>> yields
>>>> "ogrinfo test.ovf --debug on" runs for a very long time returning many
>>> lines
>>>> of this sort of stuff:
>>>> ODBC: CatalogNameL: (null)
>>>> Schema name: (null)
>>>> OGR_ODBC: Table UserMapData has no identified FID column.
>>>> OGR_ODBC: Table CHECK_CONSTRAINTS has no identified FID column.
>>>> before finally saying:
>>>> OGR: OGROpen(ODBC:un/pw at CLO/02C79D10) succeeded as ODBC.
>>>> OGR: OGROpen(test.ovf/00E17090) succeeded as VRT.
>>>> 1: UserPoint
>>>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02C79D10) dereferenced and now
>>>> destroying.
>>>> GDAL version is 1.6.0.
>>>> I have tried using no FID tag and using SrcLayer instead of SrcSQL.
>>> Anybody
>>>> know what I could do to make it see the FID? I'm guessing it would be a
>>> lot
>>>> faster if it didn't check every table in the database for an FID...
>>>> Thanks in advance for your assistance,
>>>> Dave Lowther
