[gdal-dev] ogrinfo segmentation fault
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sat Aug 21 22:57:19 EDT 2010
Bryn,
Segfault is a serious problem. Please provide a small sample dataset that
shows this problem so the problem can be identified.
On Sun, Aug 22, 2010 at 5:06 AM, Bryn Roberts <mr.bryn at gmail.com> wrote:
> Hi Chaitanya,
> Thanks for getting back to me.
> I've modified my system to use the debian testing packages and my current
> gdal-bin version is 1.6.3-4 and I still receive the Segmentation fault
> error.
> Any ideas?
> Cheers,
> Bryn
> On 19 August 2010 22:11, Chaitanya kumar CH <chaitanya.ch at gmail.com>wrote:
>> Bryn,
>> GDAL 1.5 branch is not supported right now. Can you try with the latest of
>> 1.6 or 1.7 branch?
>> On Thu, Aug 19, 2010 at 11:02 AM, Bryn Roberts <mr.bryn at gmail.com> wrote:
>>> Hi all,
>>> First, I've done a fair bit of googling for my problem and haven't got
>>> anywhere. Hopefully I am just doing something stupid and there is an easy
>>> fix!
>>> I use the gdal-bin package on my debian lenny box, mostly for MapServer
>>> to render data from MySQL Spatial.
>>> Recently the gdal-bin package upgraded to version 1.5.2-3 and around the
>>> same time MapServer stopped working when using MySQL Spatial layers.
>>> I began troubleshooting this problem by following the steps on the
>>> MapServer page for using MySQL via OGR (
>>> http://mapserver.org/input/vector/mysql.html) and discovered that
>>> executing
>>> "ogrinfo MYSQL:spatial,user=bryn,password=xxxx,port=3306"
>>> returns
>>> "Segmentation fault"
>>> That's it, I don't get any other info out and I don't know where else I
>>> can look to find more on why this error might be happening!
>>> Hope someone can help me out.
>>> Cheers,
>>> Bryn
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100822/16e45d66/attachment.html
