[gdal-dev] ecw speckling in no-data area
Ray D. Joslyn
RJoslyn at etg-sadi.com
Thu Aug 26 09:36:52 EDT 2010
Is there any way to remove the speckling in ecw files in no-data areas and re-output to ecw? There doesn't seem to be a compression scheme for ecw that doesn't produce these artifacts. I have tried the nearblack utility, but it doesn't seem to be able to create or re-write to an ecw file.
Ray Joslyn, GISP
ETG, a division of Westwood
7304 W. 130th Street, Suite 200
Overland Park, KS 66213
MAIN 913-851-4492
Direct 913-890-4804
EMAIL rjoslyn at etg-sadi.com<mailto:rjoslyn at etg-sadi.com>
FAX 913-851-8357
WEB www.westwoodps.com/etg<http://www.westwoodps.com/etg>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100826/6ce95362/attachment.html
