[gdal-dev] nonspatial column with ogr.
Frank Warmerdam
warmerdam at pobox.com
Sun Aug 29 09:34:37 EDT 2010
ahmet temiz wrote:
> thank you
> I think I need one more clarification. Doesn't "field" have same
> meaning with column ?
> or what does "field" correspond to in sql jargon ?
> I will appreciate if you make me clear
Ahmet,
For our purposes field and column are essentially the same.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
