[gdal-dev] Gdal driver not working in windows 7
Ram prasad ramprasad85 at gmail.com
Thu Dec 2 07:32:35 EST 2010
As rightly pointed out, the problem was in compiler settings.
I had compiled my driver in /MT instead of /MD
Now it is working perfectly.
But I faced a problems. I had to compile all the related libraries
using /MD too. Luckily I could. But what if I have I cannot get a MD
version of a lib?
does GDAL give the driver writer the option to do the 'delete' of
their driver object themselves (Because he does the 'new' on his heap
in GDALRegister()). There can be a function pointer like
pfnDeleteDriver in GDALDriver. If it is NULL then GDAL can do the
delete.
Thank you very very much for your support.
On Tue, Nov 23, 2010 at 2:51 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> 2010/11/22 Ram prasad <ramprasad85 at gmail.com>
>> Following is repost, because the message appeared garbled in the mailing
>> list.
>> I could not compile my code along with other formats in frmts due to
>> my insufficient experience in using nmake projects.
>> http://www.gdal.org/gdal_drivertut.html gives information on writing a
>> driver.
>> Is there a document on compiling the driver? I need to be able to
>> specify the search path for include files for the compiler and input
>> files for the linker.
> If you download the -dev package from http://vbkto.dyndns.org/sdk/  it
> should contain all the required libs and headers to compile the plugin. Make
> sure to compile with the /MD setting to use the same CRT dependency for the
> plugin and the gdal dll.
> Best regards,
> Tamas
"Love all serve all" - ..::Sri Sathya Sai::..
