[gdal-dev] [driver geoconcept] how to manage polyline with thousand of coordinates
Richard Didier didier.richard at ign.fr
Thu Dec 2 08:49:04 EST 2010
Le jeudi 2 décembre 2010 14:35:25, nicolas david a écrit :
> hi list
> I've encountered some issue with a *.gxt file and ogr2ogr.
> This file contains only one geometry with more than 5000 intermediate
> coordinates. It's goemtry type is polyline (format 2). The size of this
> polyline is too big for the char buffer of the geoconcept driver. So I've
> got a "Too many characters at line .. " error message.
> I've tried ( naively) to increase the size of this char buffer in the
> geoconcept.h file.
> struct _GCExportFileH {
>   char                  cache[kCacheSize_GCIO+1];
>   char*                 path;
> with first :
> #define  kCacheSize_GCIO          65535
> and then :
> #define  kCacheSize_GCIO          262143
> It compile and at the execution time the geoemtry line is readed but it
> leads to strange error on "OGRGeoconceptDataSource::LoadFile" method.
> More precisely on ligne 184 the
> "Open_GCIO(_pszName,_pszExt,pszMode,_pszGCT)"  method works and all
>  internal values seems ok after the return assigment the hGXT member are no
>  longer correct ( memory seems corrupt).
> I've solve this issue by splitting my polyline object on multiple polylines
> objects. But I'll be very  grateful if someone could explain to me what's
> wrong with increasing the char buffer size !
Could you file a ticket in the bug tracker, for me to follow this issue ?
> Nicolas David
Sincerely,
didier
RICHARD Didier - Chef du pôle technique du Géoportail
2/4, avenue Pasteur - 94165 Saint Mandé Cedex
Tél : +33 (0) 1 43 98 83 23
