[gdal-dev] Error: EPSG code not recognized
António Rocha
antonio.rocha at deimos.com.pt
Mon Dec 6 07:19:47 EST 2010
Hi Jean-Claude
So, how can I know which EPSG CRS codes are use this projection?
Thanks
Antonio
> Message: 2
> Date: Mon, 06 Dec 2010 12:40:28 +0100
> From: Jean-Claude Repetto <jrepetto at free.fr>
> Subject: Re: [gdal-dev] Error: EPSG code not recognized
> To: gdal-dev at lists.osgeo.org
> Message-ID: <4CFCCBAC.5050005 at free.fr>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Le 06/12/2010 11:21, António Rocha a écrit :
>> Greetings
>> I'm using gdal15 and gdal16 and I'm trying to use gdalwarp with the
>> following command:
>> gdalwarp -s_srs EPSG:9823 -t_srs EPSG:3763 file.nc file.tif and I get
>> the error:
>> ERROR 6: EPSG PCS/GCS code 9823 not found in EPSG support files. Is this
>> a valid EPSG coordinate system?
>> ERROR 1: Translating source or target SRS failed:
>> EPSG:9823
>> The thing is that this EPSG code exists and is this one:
>> http://www.remotesensing.org/geotiff/proj_list/equirectangular.html
>> Is this a bug? or is there other alternative?
>> Thanks
>> Antonio R.
> Hi Antonio,
> EPSG:9823 is not a coordinate reference system, it is only a projection
> code.
> Jean-Claude
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5677 (20101206) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
