[gdal-dev] patch for ISIS2 driver
Even Rouault even.rouault at mines-paris.org
Mon Dec 6 13:56:27 EST 2010
Ludovic,
would you mind opening a ticket in the GDAL trac with your patch attached so
it doesn't get lost ?
I see that you've cc'ed Robert Soricone. Does this mean that he or Trent Hare
have already reviewed the patch ?
Some links to public datasets if available would be helpful for testing I
think.
Best regards,
Even
Le lundi 06 décembre 2010 17:01:56, Ludovic Mercier a écrit :
> Hi,
> i have a patch for gdal 1.7.3 to improve isis2 driver.
> The patch had
> * writing functionality for QUBE object
> * grab null value
> * improve the type reading
> * can read qube with back plane, side plane and bottom plane
> * can read a file with label detached or attached.
> and i have modify nasakeyword handler to reduce sensibility of parser to
> little error on comment. (Like if we have char after end comment.)
> but i have rewrite/move a lot of lines... I use this patch for a
> research project from one year ago. I work on hyperspectral data with
> OTB library.
> I think is it possible to easily merge pdsdataset.cpp and isis2dataset.cpp
> pdsdataset work on IMAGE tag and isis2 on QUBE tag but it is the same
> workflow for all object (QUBE, IMAGE or SPECTRAL_QUBE)
> Warning for writing no geographical information are writing now, and
> create_copy is not implemented.
> Ludovic.
