[gdal-dev] GDAL/OGR Python Question
Brian Walawender
brian.walawender at noaa.gov
Mon Dec 6 15:29:24 EST 2010
Frank,
Thanks for tip. I was able to rasterize my polygon and used that to
calculate my sum. Very fast.
bw
On Fri, Dec 3, 2010 at 2:28 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Brian Walawender wrote:
>> Hello,
>> I am looking for some assistance in optimizing a section of code for
>> faster performance. Here is my problem, I have GeoTiff that contains 1 km
>> x 1 km population data over an area roughly the size of the continental US
>> (7020 x 3000). I am trying to calculate the population within a polygon.
>> I am doing this by finding the extent of the polygon and reading in that
>> section of the GeoTiff using the ReadAsArray function. At this point I can
>> quickly calculate the population within the extent by using the numpy sum.
>> However, the only way I can figure to sum the points within the polygon is
>> to iterate over the array checking each point using ogr. If the polygon is
>> very large, this can take an extended period of time. Is there a faster way
>> to calculate the population within a large polygon? My code and some sample
>> output is below.
> Brian,
> I think you would be better off rasterizing your mask polygon and operating
> on the masked raster. It might be sufficient to set all cells outside the
> region to 0 in your target raster if you are just summing. Or you might
> generate the mask separately and just check it instead of doing an
> expensive point in polygon test.
> The test script for the rasterize function is available at the following
> url and might provide a hint of how to use it.
> http://svn.osgeo.org/gdal/trunk/autotest/alg/rasterize.py
> You can also find more about the rasterize api from it's C++ docs at:
> http://www.gdal.org/gdal__alg_8h.html#50caf4bc34703f0bcf515ecbe5061a0a
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Brian Walawender
Technique Development Meteorologist
Scientific Services Division - Central Region Headquarters
816-268-3114 - Office
816-805-6497 - Cell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101206/ae5100fb/attachment.html
