[gdal-dev] image-io extension
Even Rouault
even.rouault at mines-paris.org
Thu Dec 9 14:25:27 EST 2010
Hi Viji,
I maintain the GDAL Java bindings, but the image-io GDAL plugin is another
project whose maintener is Daniele I think. He'll correct me if I'm wrong, but
I saw his name on http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL
;-) . I've CC'ed him so he has a chance to comment and explain the rational of
the patch.
I wasn't aware of this patch. I've skimmed through it quickly, and it seems
that it only replaces old-fashionned data structures like Vector to use more
trendish ArrayList + Java 1.5 generics. Well, this is certainly not a bad idea
(something to consider for GDAL 2.0 ?), but I fail to see why it was
*necessary* . I'm not particularly keen on applying this patch in GDAL
mainline as it changes the API of the Java bindings, thus breaking working
code of other users. I fail to see why ImageIO-EXT cannot use the existing
API, even if it is perhaps not as convenient as it could be if it was using
more modern Java API.
Best regards,
Even
Le jeudi 09 décembre 2010 14:18:18, Viji V Nair a écrit :
> Hi,
> I am one of the GDAL co-maintainer for Fedora, I would like to have
> the image-io extension support, currently it been supported through
> the following patch from image-io. But I dont think this is a good
> idea as the modifications are bit heavy.
> https://imageio-ext.dev.java.net/svn/imageio-ext/trunk/patches/gdal1.7.2.pa
> tch (Username : guest, Password: guest)
> Is there any work going on related to this? Please share the ideas
> Thanks
> Viji
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
