[gdal-dev] Re: Multipart to singlepart
iomeneandrei
aborruso at tin.it
Thu Dec 9 16:58:20 EST 2010
Hi Even,
Even Rouault wrote:
> Geometry have been made iterable only since GDAL 1.7.0. You need to
> upgrade
> your GDAL version or modify a bit the script to make the iteration with
> the
> OGR API.
> instead of :
> for geom_part in geom:
> addPolygon(geom_part.ExportToWkb(), out_lyr)
> try :
> for i in range(geom.GetGeometryCount()):
> geom_part = geom.GetGeometryRef(i)
now it works perfectly!!
Thank you very much,
Andrea
Andrea Borruso
email: aborruso at tin.it
website: http://blog.spaziogis.it
my 2.0 life: http://aborruso.spaziogis.it
feed: http://feeds2.feedburner.com/Tanto
38° 7' 48" N, 13° 21' 9" E
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Multipart-to-singlepart-tp5807508p5820973.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
