[gdal-dev] image-io extension
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Fri Dec 10 04:27:49 EST 2010
Ciao Even,
I have asked daniele to make those changes (which have not been reviewed yet)
in order to move away from the explicit usage of Vector and HashTable in method
signatures in favour of using the respective interfaces (List and Map).
Daniele can add more as needed...
As you mentioned this change can break old code, but it should
make the java bindings more ... javaish :).
We have other changes in the queue which we might submit to your review
early next year, but this is another topic...
Viji , I don't think you need to use the patch you are referring to since
that is needed for imageio-ext 1.1 which has not been released yet.
The latest (and greatest) is 1.0.8 which uses an older gdal version.
Ciao,
Simone.
Ing. Simone Giannecchini
GeoSolutions S.A.S.
Founder
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584962313
fax: +39 0584962313
mob: +39 333 8128928
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Thu, Dec 9, 2010 at 8:25 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Hi Viji,
> I maintain the GDAL Java bindings, but the image-io GDAL plugin is another
> project whose maintener is Daniele I think. He'll correct me if I'm wrong, but
> I saw his name on http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL
> ;-) . I've CC'ed him so he has a chance to comment and explain the rational of
> the patch.
> I wasn't aware of this patch. I've skimmed through it quickly, and it seems
> that it only replaces old-fashionned data structures like Vector to use more
> trendish ArrayList + Java 1.5 generics. Well, this is certainly not a bad idea
> (something to consider for GDAL 2.0 ?), but I fail to see why it was
> *necessary* . I'm not particularly keen on applying this patch in GDAL
> mainline as it changes the API of the Java bindings, thus breaking working
> code of other users. I fail to see why ImageIO-EXT cannot use the existing
> API, even if it is perhaps not as convenient as it could be if it was using
> more modern Java API.
> Best regards,
> Even
> Le jeudi 09 décembre 2010 14:18:18, Viji V Nair a écrit :
>> Hi,
>> I am one of the GDAL co-maintainer for Fedora, I would like to have
>> the image-io extension support, currently it been supported through
>> the following patch from image-io. But I dont think this is a good
>> idea as the modifications are bit heavy.
>> https://imageio-ext.dev.java.net/svn/imageio-ext/trunk/patches/gdal1.7.2.pa
>> tch (Username : guest, Password: guest)
>> Is there any work going on related to this? Please share the ideas
>> Thanks
>> Viji
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
