[gdal-dev] Odd 1.7.3 <> 1.8.0 trunk OGR difference (shapefile
driver?)
Roger Bivand
Roger.Bivand at nhh.no
Tue Dec 14 15:53:23 EST 2010
On Tue, 14 Dec 2010, Even Rouault wrote:
> Roger,
> thanks for your report and the precise spotting of the problem.
> The regression of behaviour you saw was not intended at all. It is now fixed in
> SVN (r21257) and I've added new test cases in the test suite r21258 to match
> that use case.
Even,
Thanks, that is great! Checked here, both with ogr2ogr and within the
rgdal for the R interface.
Agus, you can regain the functionality by anonymous checkout of GDAL and
installing from source - the odd "jumping the gun" binary you have should
probably be abandoned.
Best wishes,
Roger
> Best regards,
> Even
> Le mardi 14 décembre 2010 19:41:42, Roger Bivand a écrit :
>> Hi,
>> Agus Lobo has drawn my attention to an oddity (here using GADM Tunisia
>> shapefiles) introduced between 1.7.3 and current(ish) trunk:
>> $ ogr2ogr --version
>> GDAL 1.7.3, released 2010/11/10
>> $ ls TUN*
>> TUN_adm0.dbf TUN_adm0.shp TUN_adm1.sbn TUN_adm2.dbf TUN_adm2.shp
>> TUN_adm0.prj TUN_adm0.shx TUN_adm1.sbx TUN_adm2.prj TUN_adm2.shx
>> TUN_adm0.sbn TUN_adm1.dbf TUN_adm1.shp TUN_adm2.sbn TUN_adm.zip
>> TUN_adm0.sbx TUN_adm1.prj TUN_adm1.shx TUN_adm2.sbx TUN_readme.txt
>> $ ogr2ogr -f "ESRI Shapefile" TUN TUN_adm0.shp -nln TUN
>> $ ls TUN*
>> TUN:
>> TUN.dbf TUN.prj TUN.shp TUN.shx
>> where:
>> creates a new DSN (TUN), and populates it with files. But in 1.8.0 (SVN
>> 21235):
>> $ rm -rf TUN TUN.*
>> # swap GDAL versions
>> $ ogr2ogr --version
>> GDAL 1.8dev, released 2010/01/19
>> $ ogr2ogr --version
>> [rsb at reclus2 bigshape]$ ogr2ogr -f "ESRI Shapefile" TUN TUN_adm0.shp -nln
>> TUN
>> [rsb at reclus2 bigshape]$ ls TUN*
>> TUN_adm0.dbf TUN_adm0.shx TUN_adm1.shp TUN_adm2.sbx TUN.prj
>> TUN_adm0.prj TUN_adm1.dbf TUN_adm1.shx TUN_adm2.shp TUN_readme.txt
>> TUN_adm0.sbn TUN_adm1.prj TUN_adm2.dbf TUN_adm2.shx TUN.shp
>> TUN_adm0.sbx TUN_adm1.sbn TUN_adm2.prj TUN_adm.zip TUN.shx
>> TUN_adm0.shp TUN_adm1.sbx TUN_adm2.sbn TUN.dbf
>> TUN:
>> it creates the new DSN directory, but does not put the files inside it,
>> but rather in the working directory. If the new DSN and layer have
>> different names:
>> $ rm -rf TUN TUN.*
>> $ ls TUN*
>> $ ogr2ogr -f "ESRI Shapefile" TUN TUN_adm0.shp -nln TUN0
>> $ ls TUN*
>> it works. This also affects the R OGR interface, but it can be reproduced
>> with ogr2ogr, so it is inside OGR somewhere. Is the change intended?
>> With a different driver, it also works, so maybe it is in shape:
>> $ rm -rf TUN TUN.*
>> $ ogr2ogr -f "Mapinfo File" TUN TUN_adm0.shp -nln TUN
>> $ ls TUN*
>> TUN:
>> TUN.dat TUN.id TUN.map TUN.tab
>> as expected. Have the changes "to improve the user Shapefile experience"
>> got overenthusiastic, maybe? This breaks existing behaviour, so needs
>> justification if sustained. It looks like line 509 in
>> trunk/gdal/ogr/ogrsf_frmts/shape/ogrshapedatasource.cpp
>> with:
>> EQUAL(CPLGetBasename(pszName), pszLayerName))
>> being the smoking gun change? The DSN is TUN, not TUN.shp, but is being
>> mistaken for TUN.shp, isn't it?
>> Best wishes,
>> Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
