[gdal-dev] Internal Metadata Management
Frank Broniewski
brfr at metrico.lu
Thu Dec 16 02:33:36 EST 2010
Am 15.12.2010 16:47, schrieb Howard Butler:
> On Dec 15, 2010, at 9:30 AM, Ari Jolma wrote:
>> On 12/15/2010 05:11 PM, Frank Broniewski wrote:
>>> Hello Ari,
>>> yes that is definitely helpful. But I still wonder if it might be easier/quicker to use GeoJSON as a interchange format and tranform from geojson to other formats than using OGRs internal structure. I already have some convenience classes for creating GeoJSON structures in Python. I know there is already a geojson python module [1], but onfortunately it doesn't deal with projections afaik.
>> GDAL has support for GeoJSON too. And it seems to support projections.
> GeoJSON explicitly supports projections, and OGR's implementation tries its best to deal with them. GeoJSON's original intent is as a slightly-more-up-to-date, Javascript-consumable interchange format. A better WKT, if you will. With a light concept of features and feature collections. It's a great way to interchange geometries and (sometimes) features between softwares of the Python world, the Javascript world, and the PostGIS world.
> There are some gotchas with GeoJSON as far as features are concerned though. A GeoJSON feature object is essentially free-standing, and an array of them need not have a common schema to describe the layout of all of the features in that array. In practice, the features of an array typically have a common schema, but this requirement is not enforced in any way. This property of GeoJSON can cause some leakage in that respect.
> ESRI's JSON output is not GeoJSON, and AFAIK there is no interchange capability there.
> Howard_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hello Howard,
thank you very much for your detailed answer. I know that GeoJSON
supports projections, the before mentioned python package (from Sean
Gillies and Matt Russel) doesn't: "Version 1.0 does not consider
coordinate systems." [1]
I am doing database based CAD to GIS conversions and therefore I was
looking for an easy to use interchange format. Having used GeoJSON
before with a number of OpenLayers Web applications, I know this format
well and the really pleasant way to create this format from a number of
different data sources. My only concern was actually if it wouldn't be
more efficient to use OGRs internal data format directly. But I will be
using GeoJSON as my transport format now. So I don't have to deal too
much with OGRs C-API which I don't understand very well. I am just a
geographer, not a programmer.
Luckily I won't have to deal with ESRIs data formats - apart from
Shapefiles of course :-)
Frank
[1] - http://trac.gispython.org/lab/wiki/PythonGeoInterface
