AW: [gdal-dev] An issue about using GDALWARP to do the NTv2transformation
Schmitz, Uwe uwe.schmitz at bezreg-koeln.nrw.de
Thu Dec 16 03:50:28 EST 2010
Heng,
as Frank wrote the coordinates you try to transform are
far outside the BETA2007.gsb grid. Is it possible that
your georefrenced raster fiel lacks the Gauss-Krueger meridian
prefix? If so, you can try with a modified "+x_0=500000" parameter
on the command line.
Regards
Uwe
