[gdal-dev] RE: Convert from GeoTiff to JP2
Livneh Yehiyam
yehil at rafael.co.il
Sun Dec 19 14:40:09 EST 2010
Can anyone help?
________________________________________
Sent: Thursday, December 02, 2010 10:51 AM
To: 'gdal-dev at lists.osgeo.org'
Subject: Convert from GeoTiff to JP2
Hi
I ran into a problem converting a GeoTiff to a Jpeg200 image, using gdal_translate and the JP2ECW driver.
My geotiff has GCP's as the georeference. Here is the output from gdalinfo:
Driver: GTiff/GeoTIFF
Files: 01122010-1509.tif
Size is 1680, 916
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["arc-second",4.848136811095361e-006],
AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=1, Info=
(0,0) -> (126151.273546348,115626.820459333,0)
GCP[ 1]: Id=2, Info=
(0,916) -> (126145.399132411,115623.500933949,0)
GCP[ 2]: Id=3, Info=
(1680,916) -> (126151.213029255,115615.934065356,0)
GCP[ 3]: Id=4, Info=
(1680,0) -> (126157.194618444,115619.120192017,0)
Metadata:
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 916.0)
Upper Right ( 1680.0, 0.0)
Lower Right ( 1680.0, 916.0)
Center ( 840.0, 458.0)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
after converting to jp2 using the command:
gdal_translate -of jp2ecw 01122010-1509.tif 01122010-1509.jp2
I get this from gdalinfo:
E:\Data\test>gdalinfo 01122010-1509.jp2
Driver: JP2ECW/ERMapper JPEG2000
Files: 01122010-1509.jp2
01122010-1509.jp2.aux.xml
Size is 1680, 916
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
UNIT["degree",0.0174532925199433],
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Band 1 Block=1680x1 Type=Byte, ColorInterp=Red
Overviews: arbitrary
Band 2 Block=1680x1 Type=Byte, ColorInterp=Green
Band 3 Block=1680x1 Type=Byte, ColorInterp=Blue
I think the problem is that both projectionRef, and GCPProjection are defined. This causes Global Mapper to fail reading the geo-reference data.
Is it a known problem, or am I doing something wrong?
Thanks
Yehiyam Livneh
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
