[gdal-dev] to get postgis-polygon object using resultset in Java
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Dec 28 03:49:19 EST 2010
Ahmet,
If you are querying the postgis database directly, you can use ST_AsText()
or ST_AsBinary() to get the geometry in the WKT or the WKB format and use
OGRGeometry::importFromWkt() or OGRGeometry::importFromWkb() respectively to
load them into the OGR objects. This question is actually for the postgis
list.
2010/12/28 ahmet temiz <ahmettemiz88 at gmail.com>
> hello
> how can I get postgis-polygon object using Resultset in Java ?
> like this way :
> ResultSet rs = stmt.executeQuery(qstr);
> while (rs.next()) {
> gdal.Geometry geo=????
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> Bilgi ve CBS grubu
> Eskişehir Yolu 10. km.
> Lodumlu / Ankara
> Tel : 0 312 2872680 / 1535
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101228/5d013b4e/attachment.html
