[gdal-dev] gdal swig python's setup.py not python3 compatible
Even Rouault
even.rouault at mines-paris.org
Thu Dec 30 05:39:32 EST 2010
> I guess my question actually boils down to: how can I specify in the
> configure phase, which python to use for the bindings? E.g. I have both
> 2 and 3 on my system, and 3 is the default, but I want gdal to build and
> install the bindings for 2. Could I specify
> --with-python=/usr/bin/python2 when running configure? (Or even better,
> build and install it for both pythons in one run...)
No, AFAIK you can't specify the name of the python executable. --with-python
just accept yes or no.
Don't bother with --with-python in configure, it doesn't do much, apart from
automating the process. So just try :
cd swig/python
/usr/bin/python2 setup.py build
/usr/bin/python2 setup.py install
/usr/bin/python[3] setup.py build
/usr/bin/python[3] setup.py install
and you'll have the bindings built and installed for the 2 versions
> Thanks,
> Vincent.
> > Best regards,
> > Even
> > Le mercredi 29 décembre 2010 14:27:09, Vincent Schut a écrit :
> >> Oops, wrong conclusion. Seems more complicated than I thought, as there
> >> are some python checks in configure that use python...
> >> Lets change this into a question:
> >> as I have both python2 and python3, with /usr/bin/python linking to
> >> python3 (so python3 is the default), and gdal's python extension seems
> >> to be not python3 compatible (at least the build/install method), what
> >> would be the prefered way to have gdal's configure/make/make install use
> >> python2 for everything? E.g. use /usr/bin/python2 as executable, and the
> >> python2 site-packages dir for installing.
> >> As lots of my own scripts and other extensions I use are still not
> >> really python3-ready, I don't mind using python2 myself, but I'd like to
> >> keep the system default to python3 because I don't want to mess to much
> >> with my system's defaults (I tend to forget stuff I change manually,
> >> etc.)
> >> Tia,
> >> Vincent.
> >> On 12/29/2010 02:19 PM, Vincent Schut wrote:
> >>> Hi,
> >>> some time ago, Arch linux made the rather bold decision to have python3
> >>> as system python default, of course with a /usr/bin/python2 alternative
> >>> sitting next to it. However, as the /usr/bin/python link is pointing to
> >>> /usr/bin/python3, gdal's swig python module's setup.py is being called
> >>> with python3, and appears to be not python3 compatible:
> >>> checking for python bindings... checking for python... python
> >>> checking for location of Python Makefiles... File "<string>", line 3
> >>> print sys.prefix
> >>> SyntaxError: invalid syntax
> >>> print sys.prefix
> >>> print sys.version[:3]
> >>> found
> >>> checking where to install Python modules... /lib/python/site-packages
> >>> enabled
> >>> checking for python setuptools... File "<string>", line 3
> >>> print 1
> >>> not found
> >>> configure: checking whether we should include rasdaman support...
> >>> rasdaman support not requested.
> >>> configure: creating ./config.status
> >>> config.status: creating GDALmake.opt
> >>> Imho the easiest way to fix this would be to have a
> >>> '#!/usr/bin/python2' as first line in setup.py; I suppose every distro
> >>> has also a
> >>> /usr/bin/python2 executable/link, even if there is not yet a python3
> >>> one.
> >>> Regards,
> >>> Vincent.
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
