[gdal-dev] gdal_translate -expand rgb incompatible with geotiff
	COPY_SRC_OVERVIEWS
    Vincent Schut
    schut at sarvision.nl
    Thu Dec 30 05:52:34 EST 2010
Hi all,
Kind of a corner case, but i was hoping that gdal_translate's -expand
option (to expand colorindexed 1-band files into 3-band rgb files) would
also copy and expand the overviews when run with the (geotiff specific,
I know) create option "-co COPY_SRC_OVERVIEWS=YES". It appears to not do
so, and just discards the overviews. Would this be a bug, or maybe a
feature to add?
Use case: for a classified, indexed image, I have built overviews using
the 'mode' operator, which is obviously the most usefull for this kind
of image, and only applicable on 1-band indexed data. I want to have a
rgb version of this, but with those overviews, so the overviews should
be an rgb version of the 'mode' overviews of the original. It is
impossible to create the same overviews once the image has been expanded
into rgb; mode will result in wrong, and sometimes even weird results (I
presume mode works band-wise), and average and partners will result in
colors that are not defined in the original colorindex (which I want to
avoid, we are talking maps and legends here).
I think I can work around this by creating a separate file for each
overview level (bla.ovr, bla.ovr.ovr, and so on), expanding those, and
than using copy_src_overviews to create one file with internal overviews
again, but this feels kind of awkward, and the above seemed so elegant...
Vincent.
