[gdal-dev] GdalTools contour
Even Rouault
even.rouault at mines-paris.org
Mon Feb 1 18:41:08 EST 2010
John,
from a quick look at gdal_contour.cpp, I see it uses a float value for the
contour interval, so unless there's some cast to integer at lower level in
the contour generation code, it looks more like a limitation by GdalTools,
and not in GDAL.
Indeed another quick look at
https://trac.faunalia.it/GdalTools-plugin/browser/trunk/tools/ui_widgetContour.py
shows the use of a QSpinBox.
The QT doc specifies http://doc.trolltech.com/4.3/qspinbox.html :
"QSpinBox is designed to handle integers and discrete sets of values (e.g.,
month names); use QDoubleSpinBox for floating point values"
A text entry might be more appropriate. Anyway, you might want to address your
request to the GdalTools author instead ;-)
Best regards,
Even
Le Monday 01 February 2010 21:26:30 John C. Tull, vous avez écrit :
> Hi all,
> I noticed that the contour tool in GdalTools only accepts integers for the
> contour interval. Having this field accept float would be great for those
> of us trying to manipulate contour outputs between various units.
> Cheers,
> John_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
