[gdal-dev] Re: Proposal: gdal_muladd.py
Antonio Valentino
antonio.valentino at tiscali.it
Tue Feb 2 06:39:49 EST 2010
Hi Andrew,
Il giorno Tue, 02 Feb 2010 10:43:27 -0000
"Andrew Brooks" <arb at sat.dundee.ac.uk> ha scritto:
> Hi Antonio
> Your pixel function patch sounds interesting. I've not tried it yet,
thanks
> but how easy is it to create a stack of functions? For example if
> absdiff(b1.tif,b2.tif) is not available how would I create
> abs(diff(b1.tif,b2.tif)) ?
the idea is to write a command line tool (or a GUI one) that analyzes
the algebric expression an produces the the appropriate stack of
virtual files.
I have still not written such a tool.
If you want simply to give it a try you could do something like the
following (not tested):
$ echo diff.vrt
<VRTDataset rasterXSize="5" rasterYSize="6">
<VRTRasterBand dataType="CFloat32" band="1"
subClass="VRTDerivedRasterBand"> <Description>Difference</Description>
<PixelFunctionType>diff</PixelFunctionType>
<SimpleSource>
<SourceFilename relativeToVRT="1">cint_sar.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SrcRect xOff="0" yOff="0" xSize="5" ySize="6"/>
<DstRect xOff="0" yOff="0" xSize="5" ySize="6"/>
</SimpleSource>
<SimpleSource>
<SourceFilename relativeToVRT="1">cfloat64.tif</SourceFilename>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
$ echo abs.vrt
<VRTRasterBand dataType="Byte" band="1"
subClass="VRTDerivedRasterBand"> <Description>Abs</Description>
<PixelFunctionType>mod</PixelFunctionType>
<SourceTransferType>CFloat32</SourceTransferType>
<SimpleSource>
<SourceFilename relativeToVRT="1">diff.vrt</SourceFilename>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
$ gdal_translate abs.vrt absdiff.tif
Uses band 1 from cint_sar.tif and cfloat64.tif of the test dataset.
Note that if you use ComplexSource instead of SimpleSource you can also
apply a scaling factor.
Writing simple vrt file is not hard but if the expression is complex it
could be quite boring.
Does the example answerer your question?
best regards
Antonio Valentino
