AW: [gdal-dev] Re: ogr2ogr PGSQL_OGR_FID is not work
Christian.Strobl at dlr.de
Tue Feb 2 06:42:52 EST 2010
hi jukka,
thanks for your hint. i have read the section too fast, so PGSQL_OGR_FID seems to be an environment variable. i tried also your suggestion, it's the right way to define environment variables for windows
SET PGSQL_OGR_FID=myid
but there is no difference neither. i will try it later for linux with export.
does anybody know if this PGSQL_OGR_FID option is working at all?
thanks
christian
p.s. i tried also
SET PGSQL_OGR_FID="myid"
SET PGSQL_OGR_FID='myid'
> -----Ursprüngliche Nachricht-----
> Von: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] Im Auftrag von
> Jukka Rahkonen
> Gesendet: Montag, 1. Februar 2010 16:06
> An: gdal-dev at lists.osgeo.org
> Betreff: [gdal-dev] Re: ogr2ogr PGSQL_OGR_FID is not work
> <Christian.Strobl <at> dlr.de> writes:
> > if i try the following command
> > ogr2ogr -f PostgreSQL -nln newlayer -nlt MULTIPOLYGON
> > PG:"host=localhost
> user=admin password=xxx
> > dbname=mydb" PG:"host=localhost user=admin password=yyy
> dbname=otherdb"
> oldlayer -lco PGSQL_OGR_FID=myid
> > everything works fine but the primary key remains at the column
> > "ogc_fid" not
> at the column "myid".
> > thanks for every help
> Hi,
> I have never tried that but it seems to by in the manual page
> under subtitle "Environment variables" and not under "Layer
> creation options". With Windows it would mean giving a command
> SET PGSQL_OGR_FID=myid from command line before running
> ogr2ogr. Must be something similar with Linux.
> -Jukka-
> gdal-dev mailing list
