[gdal-dev] Projection of GEOTIFF in C# problems
Tamas Szekeres
szekerest at gmail.com
Tue Feb 2 16:18:13 EST 2010
Patrik,
The GDALInfo csharp sample application doesn't exactly follow the C version
by producing the same output. However it's pretty straight forward to report
the projection similarly using the C# API.
I've just added the required changes in the development version:
http://trac.osgeo.org/gdal/changeset/18705
Best regards,
Tamas
2010/2/2 Patrik Svensson <patsv at bredband.net>
> Hi all,
> I have problem with geotiff files created with gdal_translate when I try to
> read them with the C# bindings.
> So I tested it with the GDALInfo commands.
> GDALInfo.exe (The c-api) will output the correct projection information:
> *C:\tmp\release-1500-x64-gdal-mapserver\bin>gdal\apps\GDALInfo.exe
> w:\Lmv\F*
> *\7h0a.tif*
> *Driver: GTiff/GeoTIFF*
> *Files: w:\Lmv\Foto\7h\7h0a.tif*
> *Size is 5500, 5500 *
> *Coordinate System is `'*
> *GCP Projection =*
> *PROJCS["RT90 2.5 gon V",*
> * **GEOGCS["RT90",*
> * DATUM["Rikets_koordinatsystem_1990",*
> * **SPHEROID["Bessel 1841",6377397.155,299.1528128000009,*
> * AUTHORITY["EPSG","7004"]],*
> * AUTHORITY["EPSG","6124"]],*
> * PRIMEM["Greenwich",0],*
> * UNIT["degree",0.0174532925199433],*
> * AUTHORITY["EPSG","4124"]],*
> * PROJECTION["Transverse_Mercator"],*
> * PARAMETER["latitude_of_origin",0],*
> * PARAMETER["central_meridian",15.80827777777778],*
> * PARAMETER["scale_factor",1],*
> * PARAMETER["false_easting",1500000],*
> * PARAMETER["false_northing",0],*
> * UNIT["metre",1,*
> * AUTHORITY["EPSG","9001"]],*
> * AUTHORITY["EPSG","3021"]]*
> *GCP[ 0]: Id=1, Info=*
> * (250,250) -> (1550000,6405000,0)*
> *GCP[ 1]: Id=2, Info=*
> * (5250,250) -> (1555000,6405000,0)*
> *GCP[ 2]: Id=3, Info=*
> * (250,5250) -> (1550000,6400000,0)*
> *GCP[ 3]: Id=4, Info=*
> * (5250,5250) -> (1555000,6400000,0)*
> *Metadata:*
> * AREA_OR_POINT=Area*
> *Image Structure Metadata:*
> * INTERLEAVE=BAND*
> *Corner Coordinates:*
> *Upper Left ( 0.0, 0.0)*
> *Lower Left ( 0.0, 5500.0)*
> *Upper Right ( 5500.0, 0.0)*
> *Lower Right ( 5500.0, 5500.0)*
> *Center ( 2750.0, 2750.0)*
> *Band 1 Block=5500x1 Type=Byte, ColorInterp=Gray*
> But the c-sharp version has problems with projection string as it only
> reports this, lacking the projection data:
> *C:\tmp\release-1500-x64-gdal-mapserver\bin>gdal\csharp\GDALInfo.exe
> w:\Lmv\Foto\*
> *7h\7h0a.tif*
> *Raster dataset parameters:*
> * Projection:*
> * RasterCount: 1*
> * RasterSize (5500,5500)*
> *Using driver GeoTIFF*
> * Image Structure Metadata:*
> * 0: INTERLEAVE=BAND*
> * Upper Left (0, 0)*
> * Lower Left (0, 5500)*
> * Upper Right (5500, 0)*
> * Lower Right (5500, 5500)*
> * Center (2750, 2750)*
> *GCP Projection:*
> *GCP[0]: Id=1, Info=*
> *GCP[1]: Id=2, Info=*
> *GCP[2]: Id=3, Info=*
> *GCP[3]: Id=4, Info=*
> *GCP Equivalent geotransformation parameters:*
> *t[0] = 1549750*
> *t[1] = 1*
> *t[2] = 0*
> *t[3] = 6405250*
> *t[4] = 0*
> *t[5] = -1*
> *Band 1 :*
> * DataType: Byte*
> * ColorInterpretation: Gray*
> * Description:*
> * Size (5500,5500)*
> * BlockSize (5500,1)*
> What can I do to get the correct string to give to SpatialReference?
> (Tried both GDAL 1.6 and 1.7)
> Regards
> Patrik Svensson
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100202/29c0d16e/attachment-0001.html
