[gdal-dev] Important - GDAL 1.7.0 - Imagine/HFA Driver Produces
Corrupt Files
Howard Butler
hobu.inc at gmail.com
Fri Feb 5 09:41:14 EST 2010
On Feb 4, 2010, at 10:49 PM, Frank Warmerdam wrote:
> Folks,
> Ivan has discovered that GDAL 1.7.0 is producing HFA files that are
> corrupt - that is they are only readable with GDAL. Imagine and older
> versions of ArcGIS fail to read them. The problem is described in:
> http://trac.osgeo.org/gdal/ticket/3382
> I consider this problem very serious, and the longer that GDAL 1.7.0
> is in use the more of these corrupt Imagine files will be produced and
> cause problems for the world. For that reason, I would like to press
> ahead to produce a GDAL 1.7.1 release soon, and to mark GDAL 1.7.0 deprecated
> due to this serious bug. Does anyone feel this is overkill?
> Are there any other high priority fixes folks would like to see in a GDAL 1.7.1
> release? I am thinking of preparing an RC on Monday if there is no objection.
+1. Except for BigTIFF, the HFA driver is one of the consistent large file drivers we have. Instead of marking it deprecated, I think we should retract the release (remove it from download.osgeo.org) and immediately issue 1.7.1 RC1 today. 1.7.0 hasn't been disseminated that widely, and a new release shouldn't be that disruptive to downstream packagers that are just starting to incorporate 1.7.
Was this just an issue of limited test coverage?
Howard
