[gdal-dev] gdal_rasterize use SHP FID as burn attribute
Peter Rankor
peter.rankor at googlemail.com
Mon Feb 8 10:54:07 EST 2010
List,
I need to rasterize a polygon layer coming from a SHP file. However, the
values in the outputraster need to be the FID of the corresponding polygon.
My command:
gdal_rasterize -a FID -l FECS FECS.shp flattenedRaster.tif
I get:
Failed to find field FID on layer FECS, skipping.
And the program aborts.
Any idea how to use a FID as rasterization attribute?
Regards,
Peter
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100208/d3640144/attachment.html
