[gdal-dev] how to escape special charakter
    Suhr, Ralf
    Ralf.Suhr at itc-halle.de
    Tue Feb  9 10:19:32 EST 2010
Hello list,
how can I write the commandline to work on a dos box. The dos box says:
program "name" is not found. On linux it run fine.
ogr2ogr -f "DGN" -sql "SELECT 'LABEL(f:\"Times New Roman\",s:12pt,t:\"'
|| name || '\")' AS OGR_STYLE,  *  FROM mytable" export.dgn
"PG:dbname=..--.."
Thanks in advance.
Ralf
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100209/d0da4ff1/attachment-0001.html
