[gdal-dev] BigTIFF Overviews ( OVR files )
Even Rouault even.rouault at mines-paris.org
Tue Feb 9 17:09:54 EST 2010
Could you append the output of gdalinfo on the TIF you make overviews on and
the exact gdaladdo you're using (mainly if you use one particular resampling
algorithm) ?
Le Tuesday 09 February 2010 22:57:26 David Fogel, vous avez écrit :
> Hi:
> In the process of moving data into GeoTIFF, I am re-creating pyramids
> (OVR files).  The good news: It takes fewer than ten minutes to create
> an LZW Horizontal Differenced compressed 3.5 GB file on a Windows 7
> box using GDAL 1.70+ ( via Tamas Szekeres site; 64-bit precompiled ).
> The OVR files are problematic.  Using gdal_translate, I can resize by
> 50% in less than ten minutes.  Using gdaladdo, the first layer ( "2" )
> takes hours to complete.
> This is for SRTM 16-bit data.  It appears that something is amiss.
> Tips and tricks?
> Thanks!
> = David
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
