[gdal-dev] BigTIFF Overviews ( OVR files )
David Fogel
upperoso at gmail.com
Tue Feb 9 17:32:55 EST 2010
The gdaladdo command is below (for a single overview):
D:\SRTM\Central_North> "c:\Tamas\bin\gdal\apps\gdaladdo.exe" -r
nearest -ro --config BIGTIFF_OVERVIEW YES --config COMPRESS_OVERVIEW
LZW --config PREDICTOR 2 Central_North.tif 2
On Tue, Feb 9, 2010 at 2:26 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> And the exact gdaladdo command line you're using ? (must be sure if it's
> internal or external overviews)
> Le Tuesday 09 February 2010 23:22:05 David Fogel, vous avez écrit :
>> Hi Even:
>> The GeoTIFF file is described below (output from gdalinfo). The
>> pre-compiled code is from Tamas' site:
>> http://vbkto.dyndns.org/sdk/
>> I am using the MSVC2008 version ( scroll to the bottom of the page ).
>> This ought to be v1.7.0 with some or all of the code for HFA files
>> folded into it.
>> The workstation is running Windows 7 64-bit w/ 8 GB of RAM and too
>> much disk space to know what to do with .. for the moment.
>> Thanks.
>> = David
>> ----- % cut here % -----
>> Driver: GTiff/GeoTIFF
>> Files: Central_North.tif
>> Size is 119999, 74401
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]
>> Origin = (-31.999583000000001,60.000416333276846)
>> Pixel Size = (0.000833333333333,-0.000833333333333)
>> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> COMPRESSION=LZW
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left ( -31.9995830, 60.0004163) ( 31d59'58.50"W, 60d 0'1.50"N)
>> Lower Left ( -31.9995830, -2.0004170) ( 31d59'58.50"W, 2d 0'1.50"S)
>> Upper Right ( 67.9995837, 60.0004163) ( 67d59'58.50"E, 60d 0'1.50"N)
>> Lower Right ( 67.9995837, -2.0004170) ( 67d59'58.50"E, 2d 0'1.50"S)
>> Center ( 18.0000003, 28.9999997) ( 18d 0'0.00"E, 29d 0'0.00"N)
>> Band 1 Block=119999x1 Type=Int16, ColorInterp=Gray
>> NoData Value=-32768
>> Metadata:
>> LAYER_TYPE=athematic
>> On Tue, Feb 9, 2010 at 2:09 PM, Even Rouault
>> > Could you append the output of gdalinfo on the TIF you make overviews on
>> > and the exact gdaladdo you're using (mainly if you use one particular
>> > resampling algorithm) ?
>> > Le Tuesday 09 February 2010 22:57:26 David Fogel, vous avez écrit :
>> >> Hi:
>> >> In the process of moving data into GeoTIFF, I am re-creating pyramids
>> >> (OVR files). The good news: It takes fewer than ten minutes to create
>> >> an LZW Horizontal Differenced compressed 3.5 GB file on a Windows 7
>> >> box using GDAL 1.70+ ( via Tamas Szekeres site; 64-bit precompiled ).
>> >> The OVR files are problematic. Using gdal_translate, I can resize by
>> >> 50% in less than ten minutes. Using gdaladdo, the first layer ( "2" )
>> >> takes hours to complete.
>> >> This is for SRTM 16-bit data. It appears that something is amiss.
>> >> Tips and tricks?
>> >> Thanks!
>> >> = David
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> >> gdal-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
