[gdal-dev] Problems with C# ogr_wrap.dll
Tamas Szekeres
szekerest at gmail.com
Wed Feb 10 12:03:17 EST 2010
Hi Tom,
In this case you'll have to set a reference to ogr_csharp.dll and make sure
the unmanaged dll-s (ogr_wrap.dll and it's dependencies like proj.dll) are
available to load by the application, either by copying these dll-s into
your executing directory or make them available in the PATH environment.
Best regards,
Tamas
2010/2/10 Tom van der Putte <tom at vdputte.nl>
> Hi,
> I'm currently having a problem getting the C# OGR binaries to work on a
> 64bit WinXP Pro machine, using VS2008 Pro. Ive tried both the 32bit Binaries
> and the 64 bit binaries.
> * Using the 32bit binaries from
> http://vbkto.dyndns.org:1280/sdk/Default.aspx as well as the general FW
> windows binaries:
> I set the target platform to x86, added the reference path to the 32bit
> binaries and added those as a reference. However the ogr_warp.dll is nowhere
> to be seen in the references. Calling the Ogr.RegisterAll(); results in the
> error :"Unable to load DLL 'ogr_wrap': The specified module could not be
> found. (Exception from HRESULT: 0x8007007E)"
> When I manually try to add the dll under the references, it says it cannot
> do so, and I have to check that it is either in use, or a valid assembly.
> * Using the 64bit binaries from
> http://vbkto.dyndns.org:1280/sdk/Default.aspx, and the target platform set
> to x64, the ogr_wrap.dll file is not in the bin/debug dir, and I get an
> error: "An attempt was made to load a program with an incorrect format.
> (Exception from HRESULT: 0x8007000B)"
> If I add the ogr_warp.dll to the debug/bin folder, the "Unable to load DLL
> 'ogr_wrap': The specified module could not be found. (Exception from
> HRESULT: 0x8007007E)" error pops up.
> Any ideas?
> Cheers,
> Tom
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100210/07c308af/attachment.html
