[gdal-dev] Spatial Filters and PostGIS
Miller, Craig
craig.miller at spatialminds.com
Thu Feb 11 14:02:02 EST 2010
Thanks for the confirmation. I'll tweak my queries accordingly.
Craig
On Thu, Feb 11, 2010 at 10:53 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Miller, Craig wrote:
>> I was browsing the PostGIS driver code today and noticed that when used
>> with ExecuteSQL the spatial filters appear to be getting applied on the
>> client side instead of the PostGIS side. Am I understanding the code
>> correctly?
> Craig,
> Yes, that is correct. When using ExecuteSQL() we pass on the SQL
> directly without alternation which means we need to do the spatial
> query manually after the fact.
> On the other hand, when you access postgres/postgis through a normal
> OGRLayer, we do attempt to incorporate the spatial and attribute filters
> into the internally generated SQL used to read the features.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Craig Miller
Geospatial Software Architect
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100211/9a0e273a/attachment.html
