[gdal-dev] FWTools 2.4.7 ogr2org How to convert CSV to SQLite
table
Noli Sicad
nsicad at gmail.com
Thu Feb 11 14:38:46 EST 2010
Even,
Thanks for pointing this out.
Kumar noticed that the "- f" there was space in between. The correct
syntax is "-f"
This one (below) is working.
ogr2ogr - f SQLite Harvest.sqlite HarvestArea1.csv -dsco SPATIALITE=YES
Noli
On 2/12/10, Even Rouault <even.rouault at mines-paris.org> wrote:
> I'm not sure if the version of sqlite3.dll included in latest FWTools is
> recent enough to support reading and/or creation of spatialite databases.
> See http://bugzilla.maptools.org/show_bug.cgi?id=2099
> Le Thursday 11 February 2010 13:15:23 Chaitanya kumar CH, vous avez écrit :
>> Noli,
>> There was a problem with the order of the arguments in your command.
>> http://gdal.org/ogr2ogr.html
>> On Thu, Feb 11, 2010 at 5:37 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> > OK. Sorry
>> > This is the error,
>> > FAILURE:
>> > Unable to open datasource `harvest.sqlite' with the following drivers.
>> > -> ESRI Shapefile
>> > -> MapInfo File
>> > -> UK .NTF
>> > -> SDTS
>> > -> TIGER
>> > -> S57
>> > -> DGN
>> > -> VRT
>> > -> REC
>> > -> Memory
>> > -> BNA
>> > -> CSV
>> > -> NAS
>> > -> GML
>> > -> GPX
>> > -> KML
>> > -> GeoJSON
>> > -> Interlis 1
>> > -> Interlis 2
>> > -> GMT
>> > -> SQLite
>> > -> ODBC
>> > -> PGeo
>> > -> OGDI
>> > -> PostgreSQL
>> > -> MySQL
>> > -> XPlane
>> > -> AVCBin
>> > -> AVCE00
>> > -> DXF
>> > -> Geoconcept
>> > -> GeoRSS
>> > -> GPSTrackMaker
>> > -> VFK
>> > On 2/11/10, Chaitanya kumar CH <chaitanya.ch at gmail.com> wrote:
>> > > Noli,
>> > > There must have been some error message. What did you get?
