[gdal-dev] corrupt block on AIG dataset
Even Rouault
even.rouault at mines-paris.org
Sun Feb 14 05:57:42 EST 2010
Ömer,
Is it really a new problem ? Looking at the history of the driver and the
error message, I've the feeling it is not a new one.
You'd better open a Trac ticket and attach the dataset that causes the error.
You could also check if you get the same issue with the dataset used in the
GDAL automated test : http://download.osgeo.org/gdal/data/aig/nzdem.zip
Best regards,
Even
PS : please avoid sending private email and add gdal-dev in CC.
Le Sunday 14 February 2010 09:00:20 Ömer Özak, vous avez écrit :
> Well, I'm importing and working on AIG grids. The process will work
> sometimes and not others (even on the same file). It will give me an
> error saying there is a corrupt block. Strangely it is always when I
> issue the ReadAsArray() comand and it will say it is in X Block ref 36
> in all files. The nly thing that changes is the supposed number of bytes
> it was expecting and the number it actually received.
> Since I upgraded to GDAL1.7 it tells me the following:
> ERROR 1: Block is corrupt, block size was 0, but expected to be 8192.
> ERROR 1: IReadBlock failed at X offset 36, Y offset 2021
> ERROR 1: GetBlockRef failed at X block offset 36, Y block offset 2021
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "utils.py", line 132, in <module>
> File
> "/Library/Frameworks/GDAL.framework/Versions/1.7/Python/site-packages/osgeo
>/gdal.py", line 895, in ReadAsArray
> buf_xsize, buf_ysize, buf_obj )
> File
>/gdal_array.py", line 227, in BandReadAsArray
> ar = numpy.reshape(ar, [buf_ysize,buf_xsize])
> File
> "/Library/Frameworks/GDAL.framework/Versions/1.7/Python/site-packages/numpy
>/core/fromnumeric.py", line 152, in reshape
> return reshape(newshape, order=order)
> ValueError: total size of new array must be unchanged
> Any ideas?
> On 2/13/10 6:53 PM, Even Rouault wrote:
> > Hum, not sure to remember the issue you're talking about...
> > Le Saturday 13 February 2010 20:56:54 Ömer Özak, vous avez écrit :
> >> Hi,
> >> I read your postings about this problem being fixed. I'm getting a
> >> similar issue when I import many ArcGIS binary grids using the AIG with
> >> python. I upgraded to gdal 1.7.1 and the issue is still there. I've
> >> opened the dataset in Arcgis and they work ok, so I don't think it is an
> >> issue with the files. Do you know how one can solve this?
> >> Thanks
