[gdal-dev] GDAL_PAM_ENABLED ....Yes for reading, No for writing?
Tim Osborn
tosborn at sbcglobal.net
Sun Feb 14 22:45:56 EST 2010
It seems that when I set a GDAL_PAM_ENABLED environment variable to NO, it
not only suppresses the creation of aux.xml file (what I desire), but it
also suppresses the reading of aux files as in ds.getprojectionref() (not
desired). Is there a way to only suppress the creation of aux.xml files but
keep the ability to read aux files associated with, for example Mr.Sid
files?
Thanks
Tim Osborn
View this message in context: http://n2.nabble.com/GDAL-PAM-ENABLED-Yes-for-reading-No-for-writing-tp4572762p4572762.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
