[gdal-dev] Oracle OCI connection in Python OGR
Eric Wolf
ebwolf at gmail.com
Mon Feb 15 17:13:30 EST 2010
I'm running Oracle 11g on the same machine as the Python script.
I did test cx_Oracle and found that it wasn't working. I was using the
Unicode cx_Oracle 5.0.3. Switching to the non-Unicode cx_Oracle got it
working. But OGR is still not connecting.
Does OGR rely on cx_Oracle?
I think I'll try regressing to an older version of GDAL and see if it works.
-Eric
Eric B. Wolf New! 720-334-7734
USGS Geographer
Center of Excellence in GIScience
PhD Student
CU-Boulder - Geography
GPG Public Key: http://www.h4h.net/ebwolf.public.key.txt
On Sun, Feb 14, 2010 at 12:45 PM, Abhay <abhay.menon at gmail.com> wrote:
> On Fri, Feb 12, 2010 at 11:32 PM, Eric Wolf <ebwolf at gmail.com> wrote:
>> Thanks for the replies. Sorry I didn't give more details on the
>> environment.
>> I am running on Windows, at the command line, both ogr2ogr and the python
>> script.
>> Created an environment variable for ORACLE_SID=ORCL
>> I double-checked my OCI string by using sqlplus to connect:
>> sqlplus scott/tiger at orcl
>> This works fine. I changed the script to use that in the call to
>> ogr.Open(). No luck.
>> I imported gdal and sprinkled print 'Error:', gdal.GetLastErrorMsg() in my
>> exception handlers. I got:
>> Unable to open Oracle connection None
>> Error:
>> Still no dice. If I take the same script and modify the GetDriverByName
>> and Open to use a shapefile, it works perfectly.
>> -Eric
>> USGS Geographer
>> PhD Student
>> On Fri, Feb 12, 2010 at 6:56 AM, Abhay <abhay.menon at gmail.com> wrote:
>>> On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <ebwolf at gmail.com> wrote:
>>>> I'm using GDAL/OGR 1.6.1 with ActivePython 2.6.4-10 and
>>>> cx_Oracle-5.0.3-11g. I am trying to connect to an Oracle 11g instance.
>>>> This works:
>>>> ogr2ogr -f "KML" emp.kml OCI:scott/tiger "EMP"
>>>> What am I doing wrong. This fails, ds is None:
>>>> from osgeo import ogr
>>>> try:
>>>> d = ogr.GetDriverByName('OCI')
>>>> except:
>>>> print "Unable to GetDriverByName"
>>>> quit()
>>>> ds = None
>>>> try:
>>>> ds = ogr.Open('OCI:scott/tiger')
>>>> except:
>>>> print "Unable to open OCI connection"
>>>> quit()
>>>> if ds is None:
>>>> print "Unable to open Oracle connection", ds
>>>> quit()
>>>> lyr = ds.GetLayerByName('EMP')
>>>> number = lyr.GetFeatureCount()
>>>> print "Features: " + str(number)
>>>> USGS Geographer
>>>> PhD Student
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Hi Eric,
>>> Form your mail it not clear what is cause of the problem.
>>> There 2 scenario here
>>> 1) you are on a remote machine form where your trying to connect oracle
>>> server machine:
>>> a) Have you installed any Oracle Client in your system. Considering that
>>> you are using the complete oracle client installation you can use the
>>> following :
>>> OCI:scott/tiger@<Tnsname entry for eg. ORCL>
>>> b) if you are trying out with Instant client for 11g you should try
>>> either of the following
>>> OCI:scott/tiger@//localhost/<your ORACLE SERVICE IDENTIFIER for eg
>>> ORCL>.
>>> 2) you are on the oracle server machine where
>>> you must set the oracle SID. like the following
>>> on windows
>>> SET ORACLE_SID=ORCL
>>> or
>>> on *nix
>>> export ORACLE_SID=ORCL
>>> then try your implementation or use methods stated in 1)
>>> Rgds.
>>> Abhay.
> Hi Eric,
> What I still did not get is whether your running Oracle Server 11g on the
> same machine on which your developing.
> Also have you tried connecting the same using "cx_Oracle.Connection"
> whether this connect string is working.
> Are you using gdal-1.6.1-py2.6-win32.egg install with Python or build your
> on using SWIG python implementation.
> Interestingly, what I found is that in gdal-1.6.1-py2.5-win32.egg which
> install using easy_install seem not work with OCI driver as way it should.
> But connection string using cx_Oracle is working. So it seem
> gdal-1.6.1-py*-win32.egg is broken for OCI plugin or probably it must be
> some setup I must have overlooked will setup, if someone else is working
> with same setup could help on this or Howard could comment on this.
> I have build my own egg using latest repo of gdal build and is working. If
> you need I can share the same egg file (for python 2.6) or wait for Howard
> to compile for the latest build of GDAL-1.7 for python officially as you
> would need gdalwin32-17 for this along with OCI build plugin.
> Rgds.
> Abhay.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100215/56efe9e7/attachment.html
