[gdal-dev] Simple Q: fatal error LNK1120: 19 unresolved externals
Sjur Kolberg
Sjur.A.Kolberg at sintef.no
Mon Feb 15 19:03:30 EST 2010
Vona,
This is because the linker doesn't find the gdal_i.lib. Did you build GDAL yourself or download binaries?
Sjur :-)
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of vona
Sent: 16. februar 2010 00:51
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Simple Q: fatal error LNK1120: 19 unresolved externals
What I did is: - downloaded the latest release of GDAL here: http://trac.osgeo.org/gdal/wiki/DownloadSource - created a project, created a .cpp file and put all the required .h files in the same directory - ran debugging and got the following error: fatal error LNK1120: 19 unresolved externals Did I miss something? PS: I'm using windows XP and visual c++ 2008 express.
View this message in context: Simple Q: fatal error LNK1120: 19 unresolved externals<http://n2.nabble.com/Simple-Q-fatal-error-LNK1120-19-unresolved-externals-tp4577872p4577872.html>
Sent from the GDAL - Dev mailing list archive<http://n2.nabble.com/GDAL-Dev-f2022644.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100216/4430985e/attachment-0001.html
