Re: [gdal-dev] Oracle OCI connection in Python OGR
Ivan Lucena ivan.lucena at pmldnet.com
Mon Feb 15 23:42:10 EST 2010
Eric,
Sorry for my typo. I mean, "it was a good clue".
I did a quit test using GDAL 1.8dev, the trunk version. I build the python wrapper myself by running "setup.py bdist_wininst" with Python 2.5.4. That generates "GDAL-1.7.0.win32-py2.5.exe".
That is how it goes:
Python 2.5.4 (r254:67916, Dec 23 2008, 15:10:54) [MSC v.1310 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> from osgeo import ogr
>>> ds = ogr.Open("OCI:scott/tiger at orcl")
>>> ly = ds.GetLayer(0)
>>> ly.GetName()
'ROADS'
No problem here.
I believe that you should use a GDAL/Python wrapper compatible (UNICODE) with the Python you have.
By the way, what is the character set of your database?
select * from NLS_DATABASE_PARAMETERS;
There is also the NLS_LANG. NLS_LANG is set as a local environment variable on UNIX and is set in the registry on Windows.
I just following that clue, but can you use ogr.Open() with a local file, like a shape file?
Best regards,
Ivan
>  -------Original Message-------
>  From: Eric Wolf <ebwolf at gmail.com>
>  To: gdal-dev <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] Oracle OCI connection in Python OGR
>  Sent: Feb 15 '10 17:47
>  I'm beginning to think something is wrong at my end. I just installed
>  Python 2.5, GDAL 1.5 and cx_Oracle for Python 2.5. I'm still getting
>  the same behavior. cx_Oracle works, OGR doesn't.
>  Is the clue in my last email? I mean, the Unicode version of cx_Oracle
>  didn't work but the non-Unicode version did work. Is the OGR OCI driver
>  compiled for Unicode?
>  -Eric
>  Eric B. Wolf                    New! 720-334-7734
>  USGS Geographer
>  Center of Excellence in GIScience
>  PhD Student
>  CU-Boulder - Geography
>  GPG Public Key: [LINK: http://www.h4h.net/ebwolf.public.key.txt]
>  On Mon, Feb 15, 2010 at 3:33 PM, Ivan <[LINK:
>  mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
>  Eric,
>  Eric Wolf wrote:
>  I'm running Oracle 11g on the same machine as the Python script.
>  I did test cx_Oracle and found that it wasn't working. I was using the
>  Unicode cx_Oracle 5.0.3. Switching to the non-Unicode cx_Oracle got it
>  working. But OGR is still not connecting.
>  Does OGR rely on cx_Oracle?
>  No it doesn't but I was a good to clue.
>  I think I'll try regressing to an older version of GDAL and see if it
>  works.
>  I running GDAL/OGR/Python/OCI on OpenSUSE and it works just fine. I am
>  going to test on Windows.
>  Regards,
>  Ivan
>  -Eric
>  USGS Geographer
>  PhD Student
>  On Sun, Feb 14, 2010 at 12:45 PM, Abhay <[LINK:
>  mailto:abhay.menon at gmail.com] abhay.menon at gmail.com <mailto:[LINK:
>  mailto:abhay.menon at gmail.com] abhay.menon at gmail.com>> wrote:
>     On Fri, Feb 12, 2010 at 11:32 PM, Eric Wolf <[LINK:
>  mailto:ebwolf at gmail.com] ebwolf at gmail.com
>     <mailto:[LINK: mailto:ebwolf at gmail.com] ebwolf at gmail.com>> wrote:
>         Thanks for the replies. Sorry I didn't give more details
>  on the
>         environment.
>         I am running on Windows, at the command line, both ogr2ogr and
>         the python script.
>         Created an environment variable for ORACLE_SID=ORCL
>         I double-checked my OCI string by using sqlplus to connect:
>             sqlplus scott/tiger at orcl
>         This works fine. I changed the script to use that in the call
>  to
>         ogr.Open(). No luck.
>         I imported gdal and sprinkled print 'Error:',
>         gdal.GetLastErrorMsg() in my exception handlers. I got:
>             Unable to open Oracle connection None
>             Error:
>         Still no dice. If I take the same script and modify the
>         GetDriverByName and Open to use a shapefile, it works
>  perfectly.
>         -Eric
>         USGS Geographer
>         PhD Student
>         On Fri, Feb 12, 2010 at 6:56 AM, Abhay <[LINK:
>         <mailto:[LINK: mailto:abhay.menon at gmail.com]
>             On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <[LINK:
>                 I'm using GDAL/OGR 1.6.1 with ActivePython
>  2.6.4-10 and
>                 cx_Oracle-5.0.3-11g. I am trying to connect to an
>  Oracle
>                 11g instance.
>                 This works:
>                     ogr2ogr -f "KML" emp.kml OCI:scott/tiger
>  "EMP"
>                 What am I doing wrong. This fails, ds is None:
>                 try:
>                     d = ogr.GetDriverByName('OCI')
>                 except:
>                     print "Unable to GetDriverByName"
>                     quit()
>                 ds = None
>                 try:
>                     ds = ogr.Open('OCI:scott/tiger')
>                 except:
>                     print "Unable to open OCI connection"
>                     quit()
>                 if ds is None:
>                     print "Unable to open Oracle connection", ds
>                     quit()
>                 lyr = ds.GetLayerByName('EMP')
>                 number = lyr.GetFeatureCount()
>                 print "Features: " + str(number)
>                 Eric B. Wolf                    New!
>  720-334-7734
>                 USGS Geographer
>                 PhD Student
>                 _______________________________________________
>                 gdal-dev mailing list
>                 [LINK: mailto:gdal-dev at lists.osgeo.org]
>  gdal-dev at lists.osgeo.org <mailto:[LINK: mailto:gdal-dev at lists.osgeo.org]
>                 [LINK:
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev]
>             Hi Eric,
>             Form your mail it not clear what is cause of the
>  problem.
>             There 2 scenario here
>             1) you are on a remote machine form where your trying to
>             connect oracle server machine:
>             a) Have you installed any Oracle Client in your system.
>             Considering that you a
