[gdal-dev] CF-1.0 Convention and netCDF driver
Kyle Shannon
ksshannon at gmail.com
Tue Feb 16 16:54:13 EST 2010
I have been working quite a bit with the netcdf driver and weather data. I
am noticing that many CF-1.0 (NetCDF Climate and Forecast Metadata
Convention) tags are not supported or referenced in the driver. In many
cases this forces some data to be set to a default. I am mostly working in
the spatial reference tags and this is causing problems as I don't know
where my grids are in space.
>From the NetCDF format page:
> Georeference There is no universal way of storing georeferencing in netCDF
> files. The driver first tries to follow the CF-1 Convention from UNIDATA
> looking for the Metadata named "grid_mapping". If "grid_mapping" is not
> present, the driver will try to find an lat/lon grid array to set
> geotransform array. The NetCDF driver verifies that the Lat/Lon array is
> equally space.
> If those 2 mehtods fail, NetCDF driver will try to read the following
> metadata directly and set up georefenrencing.
> - spatial_ref (Well Known Text)
> - GeoTransform (GeoTransform array)
> or,
> - Northernmost_Northing
> - Southernmost_Northing
> - Easternmost_Easting
> - Westernmost_Easting
> Is it in the best interest of everyone (or most people) to follow CF-1.0 as
the NetCDF Format states?
regards,
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406) 829-6954
kshannon at fs.fed.us
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100216/3de5d78f/attachment.html
