[gdal-dev] installing GDAL for pythonwin: can import and use gdal, but not gdal_translate
anotherObject ytrapaet at hotmail.com
Wed Feb 17 23:59:15 EST 2010
Hello, i am new to using GDAL, from what I've looked into it seems great. I
am using pythonwin to interact with GDAL.
For installation, I followed the instructions here:
http://www.gis.usu.edu/~chrisg/python/2009/install.html (installing GDAL
manually). All my windows system variables are identical to these
instructions.
I am now able to use GDAL in pythonwin - except i am unable to access the
GDAL utilities (in my first task of utilizing GDAL, thei am in need  of the
gdal_translate).
If i can import the GDAL libraries, but cannot access the gdal_translate,
does this indicate any specific problem? I am using pythonwin 2.5 and gdal
1.6.
here is what happens in my pythonwin interactive window:
>>> from osgeo import gdal
>>> gdal
<module 'osgeo.gdal' from 'C:\Python25\lib\site-packages\osgeo\gdal.pyc'>
>>> gdal_translate
  File "<interactive input>", line 1, in <module>
NameError: name 'gdal_translate' is not defined
thanks so much for any help on this, i would love to get moving with
actually learning GDAL rather than setting it up!
View this message in context: http://n2.nabble.com/installing-GDAL-for-pythonwin-can-import-and-use-gdal-but-not-gdal-translate-tp4590165p4590165.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
