[gdal-dev] Nullable fields in OGR
Jason Roberts
jason.roberts at duke.edu
Thu Feb 18 17:09:36 EST 2010
Ragi,
Thanks for your thoughts. I know what you are saying; no need to create a
another useless layer. But by adopting one or the other APIs, I would get
locked in to whatever that API decided to support, with no way to work
around it other than to hack on a private copy of that particular API.
The "is nullable" topic is a case in point. Coming from the database world,
I personally think it is very useful to be able to interrogate a schema to
determine if a field is nullable, and in existing GIS tools I do it for
various reasons. But Frank W is lukewarm to adding it to OGR. Neither of us
is right or wrong, necessarily, but as owner of OGR (at least way more than
me), Frank will probably decide whether OGRFieldDefn deserves to be extended
to include IsNullable (or maybe it would be OGRLayer::FieldIsNullable). I
must live by that decision if I adopt OGR wholesale as my internal API.
(That said, I give big kudos to the GDAL and OGR team for listening to
people like me, fixing bugs that I report, and taking feature suggestions
into consideration. It is much nicer working in this environment than it
usually is working with ESRI, who, incidentally, required three years and
two releases to finally fix a bug I reported involving not being able to set
fields to NULL through their Python interface!)
I have not written off your suggestion #1 yet--having the ArcObjects
provider indeed makes it feasible to consider--but it may turn out to be too
onerous to constrain myself to OGR's interface.
One thing I have not mentioned is a need to support additional APIs. I am
loathe to mention this because it will be the nail in my coffin--others will
think I am crazy for sure--but the ultimate goal is to have a framework in
which I can write geoprocessing tools once, and have them work with multiple
GISes. I will probably target ArcGIS and QGIS as the first two. QGIS has
allows Python based plugins for geoprocessing, and it looked like they have
their own definition of a "layer" (probably built on OGR internally?). So
that might be a third API to wrap behind a common abstraction (or will there
be a QgisLayer driver for OGR?)
Jason
-----Original Message-----
From: rburhum at gmail.com [mailto:rburhum at gmail.com] On Behalf Of Ragi Y.
Burhum
Sent: Thursday, February 18, 2010 2:30 PM
To: gdal-dev at lists.osgeo.org; Jason Roberts
Subject: Re: [gdal-dev] Nullable fields in OGR
Jason,
Having (successfully) built abstraction layers in the past to wrap
ArcGIS APIs (aka ArcObjects), OGR (and others) for other projects, I
would strongly advice you *NOT* do it. Why? Because you end up with
some API that looks **way** to similar to ArcObjects or OGR! So why
not use one of those APIs in the first place?
The only time I would suggest to do this is when there is a specific
datasource that has a model that is radically different than what is
presented by the data abstraction layer you are using (think XML,
NoSQL datastores, etc).
If this is not your case, then I would offer something that IMHO is a
better approach. Instead of creating a common abstraction, why not use
the extensibility model of 1) OGR to wrap ArcObjects or 2) viceversa ?
1) If you want to use simply OGR as your one abstraction layer, then
use the arcobjects driver for access ESRI APIs. Use the uncommitted
patch available at http://trac.osgeo.org/gdal/ticket/3332
With this you should be able to use ArcObjects inside OGR. Simply use
OGR as it is.
If there is something that you definitely need and it is not supported
by OGR abstractions (like your NULLs comment), bring it up in this
mailing list. If the GDAL/OGR models gets extended because your need
is identified as must have - then everyone benefits.
2) Currently, the only way to do this is by paying for an expensive
FME extension and even then there are many things you cannot do
(outside of the scope of this conversation). You can also use the
ArcObjects extensibility model (not trivial) and create your own OGR
Workspace that can be accessed through the ESRI tools. I have a
half-way implementation of this which I haven't worked had time (nor
energy/will) to work on. I would be happy to share this code with you
if you want to work together on finishing it.
My two cents,
- Ragi
> Date: Thu, 18 Feb 2010 12:37:04 -0500
> From: "Jason Roberts" <jason.roberts at duke.edu>
> Subject: [gdal-dev] Nullable fields in OGR
> To: "'gdal-dev'" <gdal-dev at lists.osgeo.org>
> Message-ID: <01d201cab0c0$fc6afd80$f540f880$@roberts at duke.edu>
> Content-Type: text/plain; charset="us-ascii"
> Many relational databases allow fields to be set to NULL. Is this
supported
> in OGR? How does one detect whether a field is nullable or not?
> Looking at the class documentation, I see functions OGRFeature::IsFieldSet
> and OGRFeature::UnsetField. Are these intended for checking whether a
field
> is NULL and setting it to NULL? Or are they used for something else, such
as
> determining which fields have been modified by a caller prior to him
calling
> OGRLayer::SetFeature?
> When I looked at OGRFieldDefn, I could not find a method that might be
> intended for checking whether a field was nullable (e.g.
> OGRFieldDefn::IsUnsettable).
> A while back, Mateusz asked this:
>> Yes. Also, most applications I've seen using OGR do define their own
>> data models and translate OGRFeature to features of their own types.
>> Perhaps it would be interesting to know why they don't use OGRFeature
>> as a part of their data model, what's missing...
> I am currently evaluating whether or not I should use OGRFeature directly
in
> a data model, or wrap it. Without nullability, I am probably inclined to
> wrap it. As I have mentioned previously on gdal-dev, I'm trying to build
> something that wraps OGR and ArcGIS APIs behind a common abstraction, to
> allow development of tools that work with both. ArcGIS supports
nullability
> and it is useful in many situations, so I'd like to cleanly preserve it in
> my abstraction, even if OGR does not presently support it.
> Thanks for any thoughts you have,
> Jason
