[gdal-dev] Oracle OCI connection in Python OGR
Eric Wolf
ebwolf at gmail.com
Thu Feb 18 17:22:12 EST 2010
Maybe it's just me... but...
I'm trying to connect to another Oracle instance, on a different machine,
using basically the same code as above. I get exactly the same results. In
this case, I've tried Python 2.6.4 with GDAL 1.6.0 and Python 2.4.1 with
GDAL 1.5.2. I can connect with OGR2OGR.EXE in the same environment but
cannot connect with OGR. The Oracle instance is 11.2.0.1.0.
I'm probably going setup my own build environment for GDAL/OGR at home (on
the same system as the Oracle install). So I may just roll my own and see if
that helps. Although I wouldn't mind trying other's eggs.
-Eric
Eric B. Wolf New! 720-334-7734
USGS Geographer
Center of Excellence in GIScience
PhD Student
CU-Boulder - Geography
GPG Public Key: http://www.h4h.net/ebwolf.public.key.txt
On Mon, Feb 15, 2010 at 10:43 PM, Eric Wolf <ebwolf at gmail.com> wrote:
> Thanks Ivan,
> NLS_LANGUAGE = AMERCAN
> Reading shapefile works (still).
> Rather aggravating... I may try it on another system to see what I get.
> -Eric
> USGS Geographer
> PhD Student
> On Mon, Feb 15, 2010 at 9:42 PM, Ivan Lucena <ivan.lucena at pmldnet.com>wrote:
>> Eric,
>> Sorry for my typo. I mean, "it was a good clue".
>> I did a quit test using GDAL 1.8dev, the trunk version. I build the python
>> wrapper myself by running "setup.py bdist_wininst" with Python 2.5.4. That
>> generates "GDAL-1.7.0.win32-py2.5.exe".
>> That is how it goes:
>> Python 2.5.4 (r254:67916, Dec 23 2008, 15:10:54) [MSC v.1310 32 bit
>> (Intel)] on win32
>> Type "help", "copyright", "credits" or "license" for more information.
>> >>> from osgeo import ogr
>> >>> ds = ogr.Open("OCI:scott/tiger at orcl")
>> >>> ly = ds.GetLayer(0)
>> >>> ly.GetName()
>> 'ROADS'
>> No problem here.
>> I believe that you should use a GDAL/Python wrapper compatible (UNICODE)
>> with the Python you have.
>> By the way, what is the character set of your database?
>> select * from NLS_DATABASE_PARAMETERS;
>> There is also the NLS_LANG. NLS_LANG is set as a local environment
>> variable on UNIX and is set in the registry on Windows.
>> I just following that clue, but can you use ogr.Open() with a local file,
>> like a shape file?
>> Best regards,
>> Ivan
>> > -------Original Message-------
>> > From: Eric Wolf <ebwolf at gmail.com>
>> > To: gdal-dev <gdal-dev at lists.osgeo.org>
>> > Subject: Re: [gdal-dev] Oracle OCI connection in Python OGR
>> > Sent: Feb 15 '10 17:47
>> > I'm beginning to think something is wrong at my end. I just installed
>> > Python 2.5, GDAL 1.5 and cx_Oracle for Python 2.5. I'm still getting
>> > the same behavior. cx_Oracle works, OGR doesn't.
>> > Is the clue in my last email? I mean, the Unicode version of cx_Oracle
>> > didn't work but the non-Unicode version did work. Is the OGR OCI driver
>> > compiled for Unicode?
>> > -Eric
>> > USGS Geographer
>> > PhD Student
>> > GPG Public Key: [LINK: http://www.h4h.net/ebwolf.public.key.txt]
>> > On Mon, Feb 15, 2010 at 3:33 PM, Ivan <[LINK:
>> > mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
>> > Eric,
>> > Eric Wolf wrote:
>> > I'm running Oracle 11g on the same machine as the Python script.
>> > I did test cx_Oracle and found that it wasn't working. I was using the
>> > Unicode cx_Oracle 5.0.3. Switching to the non-Unicode cx_Oracle got it
>> > working. But OGR is still not connecting.
>> > Does OGR rely on cx_Oracle?
>> > No it doesn't but I was a good to clue.
>> > I think I'll try regressing to an older version of GDAL and see if it
>> > works.
>> > I running GDAL/OGR/Python/OCI on OpenSUSE and it works just fine. I am
>> > going to test on Windows.
>> > Regards,
>> > Ivan
>> > -Eric
>> > USGS Geographer
>> > PhD Student
>> > On Sun, Feb 14, 2010 at 12:45 PM, Abhay <[LINK:
>> > mailto:abhay.menon at gmail.com] abhay.menon at gmail.com <mailto:[LINK:
>> > mailto:abhay.menon at gmail.com] abhay.menon at gmail.com>> wrote:
>> > On Fri, Feb 12, 2010 at 11:32 PM, Eric Wolf <[LINK:
>> > mailto:ebwolf at gmail.com] ebwolf at gmail.com
>> > <mailto:[LINK: mailto:ebwolf at gmail.com] ebwolf at gmail.com>> wrote:
>> > Thanks for the replies. Sorry I didn't give more details
>> > on the
>> > environment.
>> > I am running on Windows, at the command line, both ogr2ogr and
>> > the python script.
>> > Created an environment variable for ORACLE_SID=ORCL
>> > I double-checked my OCI string by using sqlplus to connect:
>> > sqlplus scott/tiger at orcl
>> > This works fine. I changed the script to use that in the call
>> > to
>> > ogr.Open(). No luck.
>> > I imported gdal and sprinkled print 'Error:',
>> > gdal.GetLastErrorMsg() in my exception handlers. I got:
>> > Unable to open Oracle connection None
>> > Error:
>> > Still no dice. If I take the same script and modify the
>> > GetDriverByName and Open to use a shapefile, it works
>> > perfectly.
>> > -Eric
>> > USGS Geographer
>> > PhD Student
>> > On Fri, Feb 12, 2010 at 6:56 AM, Abhay <[LINK:
>> > <mailto:[LINK: mailto:abhay.menon at gmail.com]
>> > On Fri, Feb 12, 2010 at 2:48 PM, Eric Wolf <[LINK:
>> > I'm using GDAL/OGR 1.6.1 with ActivePython
>> > 2.6.4-10 and
>> > cx_Oracle-5.0.3-11g. I am trying to connect to an
>> > Oracle
>> > 11g instance.
>> > This works:
>> > ogr2ogr -f "KML" emp.kml OCI:scott/tiger
>> > "EMP"
>> > What am I doing wrong. This fails, ds is None:
>> > try:
>> > d = ogr.GetDriverByName('OCI')
>> > except:
>> > print "Unable to GetDriverByName"
>> > quit()
>> > ds = None
>> > try:
>> > ds = ogr.Open('OCI:scott/tiger')
>> > except:
>> > print "Unable to open OCI connection"
>> > quit()
>> > if ds is None:
>> > print "Unable to open Oracle connection", ds
>> > quit()
>> > lyr = ds.GetLayerByName('EMP')
>> > number = lyr.GetFeatureCount()
>> > print "Features: " + str(number)
>> > Eric B. Wolf New!
>> > 720-334-7734
>> > USGS Geographer
>> > PhD Student
>> > _______________________________________________
>> > gdal-dev mailing list
>> > [LINK: mailto:gdal-dev at lists.osgeo.org]
>> > gdal-dev at lists.osgeo.org <mailto:[LINK: mailto:
>> > [LINK:
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev]
>> > Hi Eric,
>> > Form your mail it not clear what is cause of the
>> > problem.
>> > There 2 scenario here
>> > 1) you are on a remote machine form where your trying to
>> > connect oracle server machine:
>> > a) Have you installed any Oracle Client in your system.
>> > Considering that you a
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100218/b3f3c83b/attachment.html
