[gdal-dev] Re: Best way to add geo-referencing to a PNG
    Jukka Rahkonen
    jukka.rahkonen at mmmtike.fi
    Fri Feb 19 03:43:43 EST 2010
Christopher Barker <Chris.Barker <at> noaa.gov> writes:
> That seems to get the basics: QGIS puts it in the right place on the
> map, and gdal_translate seems to be able to make a geotiff out of it.
> However, I'd like to be able to put a bit more information in, like that
> it's wgs84, and geo-coordinates. How can I do that? It seems an
> *.aux.xml file should be able to do what I want. but I don't what to put
> in that.
I would convert them to geotiffs with -a_srs option for telling it is in wgs84.
gdal_translate -of GTiff -a_srs epsg:4326 image.png image.tif
-Jukka Rahkonen-
