[gdal-dev] Re: Add GCP's to a file
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri Feb 19 05:02:47 EST 2010
Kim Besson <kimbesson1981 <at> gmail.com> writes:
> Greetings
> I have a file, in HDF4 format, and I need to add GCP's points in order to
later warp that file. How can I add that information to a HDF? it can be a
Geotiff if it's easier.
Gdal_translation has on option
[-gcp pixel line easting northing [elevation]]*
I know it works with tiffs but I have not tried it with HDF4. Some working
examples and considerations about this is hidden inside a document
http://www.scangis.org/scangis2007/papers/r3_rahkonen.pdf
-Jukka Rahkonen-
