[gdal-dev] When is GDAL_DATA environment variable read by OGR?
Mateusz Loskot mateusz at loskot.net
Fri Feb 26 14:28:06 EST 2010
Jason Roberts wrote:
> I am curious to know when OGR will read the GDAL_DATA environment
> variable.
It is set during construction of driver managers of
GDAL
http://trac.osgeo.org/gdal/browser/trunk/gdal/gcore/gdaldrivermanager.cpp?rev=18770#L98
OGR
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/generic/ogrsfdriverregistrar.cpp?rev=18770#L67
What in practice means, during during first access to any of these two
driver managers. This usually happens when a client calls
either GDALAllRegister
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/gdalallregister.cpp?rev=18207#L73
or OGRRegisterAll
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/generic/ogrregisterall.cpp?rev=18449#L38
(GDAL_DATA is shared among GDAL and OGR)
> After looking at the code and reviewing this
> <http://lists.osgeo.org/pipermail/gdal-dev/2009-May/020584.html>
> email thread, it appears that the environment variable is currently
> only read at initialization time
> (OGRSFDriverRegistrar::OGRSFDriverRegistrar() is one such place), and
>  that changes to the variable after initialization time will not be
> recognized. Is that correct?
AFAIU, yes.
> Do you anticipate that that behavior will change in the future?
I don't know.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
