[gdal-dev] buiding gdal with Visual C++ 2008
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 7 09:47:41 EST 2010
Martin,
This is more of a VS problem. I had similar, but not the same,
problems on my system.
Try to do a 'rebuild' instead of 'build'.
If this doesn't solve the problem, just follow the error messages or
google "File already exists or cannot be found." or other error
messages.
On Thu, Jan 7, 2010 at 6:42 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> I am trying to build GDAL with Visual C++ 2008 Express, I am getting
> the following error
> ren jdsample.c jdsample12.c
> NMAKE : fatal error U1077: 'ren' : return code '0x1'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 9.0\VC\bin\nmake.EXE"' : return code '0x2'
> Stop.
> Stop.
> NMAKE : fatal error U1077: 'for' : return code '0x1'
> Stop.
> Stop.
> Project : error PRJ0019: A tool returned an error code from
> "Performing Makefile project actions"
> I am not sure what is wrong (no experience with VC compiler...). Thanks, Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
