[gdal-dev] Is their a way by using the bounding box and the png
to convert it into a geotiff?
Even Rouault
even.rouault at mines-paris.org
Sun Jan 10 11:02:09 EST 2010
John,
You should rather use "gdal_translate -a_srs EPSG:4326 -a_ullr ulx uly
lrx lry src.png dst.tif" to set the coordinates of the upper left (ulx,
uly) and lower right corners (lrx,lry) of your PNG. See
http://gdal.org/gdal_translate.html
John Mitchell a écrit :
> When trying to convert a png to geotiff which is listed below:
> /gdalwarp -s_srs epsg:4326 -t_srs
> epsg:4326 "C:\Documents and
> Settings\jmitchell.INSEQUENCE2\Desktop\ows2121.png"
> "C:\Documents and Settings\jmitchell.INSEQUENCE2\Desktop\ows2121.tif"/
> I get the following error:
> /ERROR 1: Unable to compute a transformation between pixel/line
> and georeferenced coordinates for C:\Documents and
> 2\Desktop\ows2121.png.
> There is no affine transformation and no GCPs./
> I have the coordinate bounding box that was used to create the
> original png.
> Is their a way by using the bounding box and the png to convert it
> into a geotiff?
> Thanks,
> John
> John J. Mitchell
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
