[gdal-dev] get projection zone and datum using gdal functions
Shawn GONG
SGONG at mdacorporation.com
Tue Jan 12 14:20:29 EST 2010
Hi list,
I use gdal2tiles.py to generate KML for Google Earth.
gdal2tiles.py requires gdal_translate and gdalwarp to convert images to EPSG:4326
If an optical image is in UTM, then "gdalwarp -s_srs '+proj=utm +zone=## ...'
Has anybody extracted projection info using Gdal Python function? I can "img_ds.GetProjection()" and then parse the projection string, but this is tedious.
Are there Python functions I can call to get the UTM zone and datum?
Thanks,
Shawn
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100112/ee8c1912/attachment.html
