[gdal-dev] Memory use in GDALDriver::CreateCopy()
Even Rouault even.rouault at mines-paris.org
Tue Jan 12 18:38:56 EST 2010
Ozy,
Did you try with gdal_translate -of NITF src.tif output.tif -co
BLOCKSIZE=128 ? Does it give similar results ?
I'm a bit surprised that you even managed to read a 40Kx100K large NITF
file organized as scanlines. There was a limit until very recently that
prevented to read blocks whose one dimension was bigger than 9999. This
was fixed recently in trunk ( see ticket
http://trac.osgeo.org/gdal/ticket/3263 ) and branches/1.6, but it has
not yet been released to an officially released version. So which GDAL
version are you using ?
Does the output of gdalinfo on your scanline oriented input NITF gives
something like :
Band 1 Block=40000x1 Type=Byte, ColorInterp=Gray
Is your input NITF compressed or uncompressed ?
Anyway, with latest trunk, I've simulated creating a similarly large
NITF image with the following python snippet :
import gdal
ds = gdal.GetDriverByName('NITF').Create('scanline.ntf', 40000, 100000)
ds = None
and then creating the tiled NITF :
gdal_translate -of NITF scanline.ntf tiled.ntf -co BLOCKSIZE=128
The memory consumption is very reasonnable (less than 50 MB : the
default block cache size of 40 MB + temporary buffers ), so I'm not
clear why you would have a problem of increasing memory use.
ozy sjahputera a écrit :
> I was trying to make a copy of a very large NITF image (about 40Kx100K
> pixels) using GDALDriver::CreateCopy(). The new file was set to have
> different block-size (input was a scanline image, output is to have a
> 128x128 blocksize). The program keeps getting killed by the system
> (Linux). I monitor the memory use of the program as it was executing
> CreateCopy and the memory use was steadily increasing as the progress
> indicator from CreateCopy was moving forward.
> Why does CreateCopy() use so much memory? I have not perused the
> source code of CreateCopy() yet, but I am guessing it employs
> RasterIO() to perform the read/write?
> I was trying different sizes for GDAL  cache from 64MB, 256MB, 512MB,
> 1GB, and 2GB. The program got killed in all these cache sizes. In
> fact, my Linux box became unresponsive when I set GDALSetCacheMax() to
> 64MB.
> Thank you.
> Ozy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
