[gdal-dev] gdal_translate JPEG to GeoTiff (help! no one
answered...)
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Jan 14 07:18:43 EST 2010
Marco,
Please provide the gdalinfo of the source image.
On Thu, Jan 14, 2010 at 4:34 PM, Marco Afonso <taviroquai at gmail.com> wrote:
> Hi all,
> I'm new to gdal tools.
> I'm trying to transform a JPEG world image to GeoTiff.
> My jpeg world map image is cropped to fit on -180.0, -59.1, 180, 90 (minx,
> miny, maxx, maxy - EPSG:4326).
> Here are the steps:
> % gdal_translate -of GTiff -a_srs EPSG:4326 -co "TILED=YES" -co
> "JPEG_QUALITY=100" worldmap_hires2.jpg worldmap2.tif
> Input file size is 15000, 6225
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> % sudo gdalinfo worldmap2.tif
> Driver: GTiff/GeoTIFF
> Files: worldmap2.tif
> Size is 15000, 6225
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.2572235629972,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (-180.017964071749986,59.117964071850004)
> Pixel Size = (0.035928143500000,-0.035928143700000)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left (-180.0179641, 59.1179641) (180d 1'4.67"W, 59d 7'4.67"N)
> Lower Left ( -180.018, -164.535) (180d 1'4.67"W,164d32'5.03"S)
> Upper Right ( 358.904, 59.118) (358d54'15.08"E, 59d 7'4.67"N)
> Lower Right ( 358.904, -164.535) (358d54'15.08"E,164d32'5.03"S)
> Center ( 89.4431122, -52.7083832) ( 89d26'35.20"E, 52d42'30.18"S)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Red
> Band 2 Block=256x256 Type=Byte, ColorInterp=Green
> Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
> Corners are not what i want. I would like to obtain -180.0, -59.1, 180, 90
> (minx, miny, maxx, maxy).
> I'm using ubuntu 9.10 and the package gdal-bin 1.6.3-1
> It there any problem with my image? What should I do?
> Thanks in advance,
> Marco
> Best regards,
> Marco Afonso
> ___________________________________
> The soul is much more than the sum of all body parts
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100114/650dc0b9/attachment.html
