[gdal-dev] gdal_translate JPEG to GeoTiff (help! no one
	answered...)
    Chaitanya kumar CH
    chaitanya.ch at gmail.com
    Thu Jan 14 10:46:33 EST 2010
Marco,
You mentioned that you cropped the original image. I guess you left
the meta-data containing the projection info intact. See if you get
the correct locations on the map with the original uncropped image.
Better yet, check the original image using the '-projwin' option in
gdal_translate.
On Thu, Jan 14, 2010 at 5:56 PM, Marco Afonso <taviroquai at gmail.com> wrote:
> Thanks for answering!
> Did not know that gdalinfo could give information about jpeg files.
> I thought that only files with geo-reference information, like GeoTiff, could give results.
> Here is:
> Driver: JPEG/JPEG JFIF
> Files: worldmap_hires2.jpg
> Size is 15000, 6225
> Coordinate System is `'
> Origin = (-180.017964071749986,59.117964071850004)
> Pixel Size = (0.035928143500000,-0.035928143700000)
> Image Structure Metadata:
>   SOURCE_COLOR_SPACE=YCbCr
>   INTERLEAVE=PIXEL
>   COMPRESSION=JPEG
> Corner Coordinates:
> Upper Left  (-180.0179641,  59.1179641)
> Lower Left  (    -180.018,    -164.535)
> Upper Right (     358.904,      59.118)
> Lower Right (     358.904,    -164.535)
> Center      (  89.4431122, -52.7083832)
> Band 1 Block=15000x1 Type=Byte, ColorInterp=Red
>     COMPRESSION=JPEG
> Band 2 Block=15000x1 Type=Byte, ColorInterp=Green
>     COMPRESSION=JPEG
> Band 3 Block=15000x1 Type=Byte, ColorInterp=Blue
>     COMPRESSION=JPEG
> Ahh... I see the corners...
> What should i do to change the corners? I would like to obtain -180.0, -59.1, 180, 90 (minx, miny, maxx, maxy).
> Best regards,
> Marco Afonso
> ___________________________________
> The soul is much more than the sum of all body parts
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.241582N 80.142635E
