[gdal-dev] Locking of Open Shapefile
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 15 20:40:31 EST 2010
Joel Odom wrote:
> I've discovered that when I use OGRSFDriverRegistrar::Open to open a
> Shapefile, the file remains locked so that another process can't open
> the file until after I've called OGRDataSource::DestroyDataSource. Is
> there any way to prevent the file from being locked? Thanks!
Joel,
Modern versions of GDAL/OGR route the open request for .shp and .dbf
files through VSIFOpenL(). The Win32 implmentation calls CreateFile()
with the sharing flags:
FILE_SHARE_READ | FILE_SHARE_WRITE
As far as I know, this means that any other application which also tries
to open the files allowing shared access should be ok. Is it possible
you are using quite an old version of GDAL/OGR? Or that the other
application is requesting exclusive access?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
